I don't have the loud sound at startup, but I definitely have that low engine knock sound you're referring to. Several members here have it, actually. It seems to be a normal issue with this engine, and I don't think it'll cause any problems in the future if the sound doesn't bother her too much.M35SFIREMEDIC wrote:Hey guys, I'm trying to help out a friend. She has a 2010 G37 and when she starts the engine she hears a loud noise and then she hears a low engine knock. The dealership says it might be a pully but it sounds like a possible oil pimp. The noise started after oil change. I also posted this on the G37 engine forum. Any suggestions? Thanks for replies.
Oh, never mind...M35SFIREMEDIC wrote:@ Antzrus, oops type O.
where is her oil level -- after the oil change and hearing the noise?? does the noise continue??? does the engine run hot??? it would suck to be the oil pump on a relatively 'new' car... maybe post a video??M35SFIREMEDIC wrote:Hey guys, I'm trying to help out a friend. She has a 2010 G37 and when she starts the engine she hears a loud noise and then she hears a low engine knock. The dealership says it might be a pully but it sounds like a possible oil pimp. The noise started after oil change. I also posted this on the G37 engine forum. Any suggestions? Thanks for replies.
It's nice to know what's wrong with your car, and not all dealers are honest. Besides, by starting a discussion here, forum members can hope for an update once the dealer fixes it under warranty, and then we have another problem and fix documented for the future when some other vehicle isn't under warranty.zerg711 wrote:Unless the owner has a ton of miles on the car, I don't understand why you are asking question on the boards when you should take the car in to the dealer and have them fix it under warranty. It is a 2010 right?
No offense at all. I'd love to see this issue resolved as well.M35SFIREMEDIC wrote:WOW !!!! Let me see if I understand. Several members have had this problem, and no one has come up with a solution?? I assume that my friend will let the stealership replace whatever they think the problem is since the car is still under warranty, but I don't except the answer that this is an issue that infiniti car owners will just have to get use too..This sounds like some carmax BS, I had a brake issue with a car I purchased from carmax and they told me I would have to just deal with the scrubbing sound coming from the brakes because the car was still stopping. Needless to say I went ape$#!+ on them and they had to refund my money. Please understand I'm not coming down on you( GenericM35) because I hate smart a** replies, I'm just trying to help a friend because I've been taken by the stealership before myself. Thanks for reply.
