I have Changed out the
Autolite AP3924 Platinum/Copper Core Plugs for the correct plugs that Go in this Car, The
NGK Laser Cut Double Platinum PFR5G-11 Plugs which is supposed to be the standard plugs according to the original 1993 Infiniti J30 Shop Manual from the trunk compartment
(Pg. MA-13/Maintenance Section). I Must say I was shocked by the fine point on the electrode of these NGK plugs, that was a first in spark plug technology for me. In any case I confirmed that all 6 plugs were correctly gapped at
".044". I have adjusted the Throttle Sensor. I am not 100% on what the correct idle speeds are for the 1993 J30 and how to adjust them. I had to replace two Ignition Coils on Plugs 5 and 6 in the back as I damaged the original ones installing them (Very Long story), Thank Got for Salvage Yards. They Only had One 1993 Infiniti J30 there on the Lot and absolutely No Z-Cars, Thank God the Ignition Coils were there.
The Car runs great over 2000 RPMs and even better with the correct plugs. I was never loosing gas mileage or performance and I am still not. My Service Engine Light has not blinked at any time. I know that I could manually check the ECM but I have not figured how to unmount it from the kick panel and I really would not want to force anything to damage it as this car has cost me a chunk of change this month, that I personally don't have.
Basically Any suggestions, I would welcome on the next course of action in a step by step format would be most helpful.
Thanks,
Larry
1993 Infiniti J30
138737 original miles
