BadMojo »
https://forums.nicoclub.com/badmojo-u5205.html
Mon Sep 13, 2004 5:31 pm
If the engine is moving noticeably at start-up, I agree it sounds like motor-mounts. As much as I'd like to go with the "massive low end torque theory"...I'd say motor mounts.
You can try revving the engine in neutral while someone watches to see if it's rocking back and forth. Even the pitiful engine in my dad's old VW Golf moved at least an inch when he'd give it some gas (the mounts were shot to hell).
And...uh...no offense, but how would you see the engine moving under load (ie. on the road) anyway?
If the car is otherwise running fine, I'd definitely think motor mounts would be the prime suspect. You can get some Nismo mounts for fairly cheap, and depending on your level of mechanical aptitude, you can install 'em yourself.
76K miles seems a bit low to have bad motor mounts already, but I can't think of anything else that it could be if the car is running OK otherwise.
Just how much does the engine move when you start it up anyway?
