leper421 wrote:Fuel injector most definately do tick, some very loudly. If you have a stethoscope, or can ghetto-rig one, move it around the valve cover, and put it on top of each injector untill you find where the noise is coming from.
that's how i found my #3 injector was bad.leper421 wrote:Fuel injector most definately do tick, some very loudly. If you have a stethoscope, or can ghetto-rig one, move it around the valve cover, and put it on top of each injector untill you find where the noise is coming from.
Supafly wrote:it very well could be dirty hydraulic lifters. try running a can of BG MOA additive in your engine oil. that stuff worked wonders on my miata a couple years ago that had horrible lifter tick and my SR just recently had a slight tick. i added the stuff and within two drives i was without ticking.
KSee777 wrote:I had the same problem. And yes it was the lifters. I used BG MOA and the ticking went away. EXCEPT, around Houston, you can't get ahold of this unless you're a mechanic. I looked everywhere and can not find them. I wanted to use BG on my other cars... but I guess I'm SOL.
