engine is ticking now wtf???
TylerS13
Car: 1990 240sx
hey guys my motor used to start ticking when i would first start the car then go away and now it just does it all the time does anyone know what this could be i was thinking lack of oil in the head cuz of a bad pump but im not sure. btw it has plenty of oil.
TylerS13
Car: 1990 240sx
any suggestions?
moso
Car: 89 240sx ka24de 5spd
90 240sx ka24de RIP
your probably getting ticking from your rocker arms, they have a little hydraulic lifters in them that can get stuck or collapse. there is a write up about them on the tech page i believe. check it out. :dblthumb:
TylerS13
Car: 1990 240sx
kk cuz it was ticking kinda slowly but loud, and now its ticking alot faster but it's al little more quiet? does this sound like rocker arms?
seang
Car: Ford Fiesta ST
How many miles are on the engine and are the timing chain guides stock?
TylerS13
Car: 1990 240sx
136k and yeah i believe so i dont think anyone has changed anything on that motor since it was new excpet the oil, but i haven't have the valve cover off so i havent seen anything under there yet.
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
Could be the chain guide. Take it off before it comes off on its own. And if that doesn't do it it may be time to bleed and reshim the lifters.
TylerS13
Car: 1990 240sx
how much are new timing chain guides? i'm assuming i'll have to replace it if it's bad? and i just did an oil change but it's still ticking so i might try to find a set of lifters and a cam for cheap.
OutToWinPAHC
Nissan RB20 E46 RHD
1990 Nissan Patrol
Guides are to be removed and not replaced, its a Nissan TSB. Dont replace the lifters, just have them shimmed (valve adjustment, lash adjustement). And check oil pressure.
TylerS13
Car: 1990 240sx
ok cool thanks man
TylerS13
Car: 1990 240sx
how do you check the oil pressure what tools do you need and how do you hook them up? also how do you pull the chain guide off and will it mess up my timing or put more slack in the chain if i pull the guide out?
moso
90 240sx ka24de RIP
i believe you have a sohc motor and if you do you need to replace those guides with metal backed ones and to do so just follow the fsm. as far as the oil pressure goes you can get a gauge and sending unit from autometer, i believe you will need a sandwitch plate for your oil filter assembly to install it, or you can get an oil pressure tester but they can be a pain to use as you still need to find a place to hook it up (get the one with the most adapters!!)
TylerS13
Car: 1990 240sx
anyone have a set of rockers for sale for some reason i cant find anything in the orlando area.
xKnownShadowX
Car: 94 Q45a
That lifter write up isn't useable.I tried it and I can't remove the lifters at all just a heads up.
