Engine is in and running!!!!
Imissmyturbo
Car: Car's, Turbo's, sking
I spent this past weekend swaping out my KA for the RB25DET. I removed the KA friday night and painted the engine bay silver to match my car. I then mounted up the RB saturday moring and spent most of the day hooking stuff up (Hoses, suspesion, ext.) Today I did the "8 step wirering" and got it running. Started up on the first try!! Runs very smoothly. I did't wire up and of the transmission sensors or oil pressure sensor. The only problem is the car won't rev up. It sounds like it cuts out around 1800-2000 and it sounds like a rev limiter is kicking in. I have all the charge piping on and secure and all the vacum ports that are not being used pluged. Are any of the sensors on the lower harness needed to make it rev up?
JonPowell
Car: Cars, Music, My family
Mine had that problem when I had a boost leak. What RPM does it idle at (if you had to guess) Might be in some kind of "safe mode"
NISMO_RB25
Car: 1992 240SX with RB25DET, 1987 RX-7 TII
congrats!!fortunately I didn't have that problem but do a search for "safe mode", as I do remember reading someone having that problem on here at some point.
Imissmyturbo
Safe mode would be at 3,000 RPM's if I remeber correctly. I guess I will have to wire up the diagnostic conector and check engine light to get it to work. I know the boost controler is not hooked up wtih the vacum lines (it is with the electrical conector. Also the boost presure sensor isn't hooked up but I think that is only for the gauge right? Was anyone else shifter really high when the engine was in place? It is like 3-4 inches higher then the stock KA one. I guess I will want to cut it.
Imissmyturbo
some picshttp://community.webshots.com/user/92rb25det
dekand
Car: 1995 240sx SE
saweeet... sooo many rb25 swaps happening right now its so great, i can't wait to get mine in!
kouki-gymkhana
Car: 1993 Nissan 240SX (only 90,000 mi!)
Yes!! I didn't think anyone was doing the RB swap in the Philly area. It's so glad to see that there's one going on as I'd like to get my swap going sometime this year (I have an s13 too). Good luck and keep us posted!-kouki:D
BoostFab
Car: S13cp, S13fb, S14z
Imissmyturbo: are you using custom mounts?
Imissmyturbo
Nope...I just got a driveshaft ordered today form a place in NV. They said it would be sent out tomarrow! When I find the there website I will post a link to it.
BoostFab
so, r33 cross member were used? how does the shifter position in the cabin--is it relatively toward the front as pictured by Night?
JonPowell
It does sit a bit forward, but nothing you cant deal with/get used to. Doesnt interfere with performance at all. At least on mine it was that way.
Imissmyturbo
The one thing I don't like about the shifter is it's way to high. The thow isn't too long but I have to reach up for it. I didn't put my console cover back over the shifter but I think it ay touch.
So anyone know how to wire up the gauges or and transmission harness?
JonPowell
You know I do...get ahold of me tonight and I will see what I can do for you or email me now [email protected]
kevy8up
congrats....i think its a beautiful thing to see RB's going in.
Imissmyturbo
BoostFab
how much did you paid for the drive shaft there?
Imissmyturbo
It's like 350-380 plus shipping
Shift_Down
Car: cars, cars and oh yeah cars
wow, alot cheaper then what you thought huh..?was it by yellow freight?
BoostFab
OT: night; you're in town already!
Imissmyturbo
Can anyone tell me what the yellow/pink wire from the insturment cluster goes to?
JonPowell
Is it labelled at all?email me some pics and I will try to figure it out for you.
Imissmyturbo
If I follow the wire on the curcuit board it seams to be a ground for most of the guages but when I ground the wire it blows the fuse for the gauges. Also the Grey/red wire at the ECU according to my diagrams is for the speed sensor input (pin 53) but that wire is used it the 8 step program to guve power to the ECU. Am I wrong about pin 53 being the speed sensor input? http://www.meggala.com/rb25detenglish.html
Imissmyturbo
Sorry the wire is yellow/purple that I was talking about two post up..not yellow/pink.
