wild_maxx wrote:since all the numbers are almost the same do you guys think i may be a valve stuck or something like that. i could hear a faint whistle sound after my BOV would release. could hardly hear it but it never did that before. and it sounds like i have an exhaust leak but i dont. i checked all my pipes and they arent leaking.
leakdown would show it. run pressurized air down each cylinder with compression tester hose and air compressor with regulator and see where the air comes out.
if it crosses cylinder to cylinder, then ring lands could be shot. if it comes out of the exhaust ports, then the valves are somehow opened, etc.
it is alot lower than before. 170 vs. 120 but they were even across each cylinder as you mentioned. hmm.
