engine/intake check light
ESPER
hello, last year when i installed my short ram intake on my 95, the check engine light came on after i was done, so i unplugged my battery for 24 hours to reset the ECU. well the other day, i disconnected my intake system, tried to coneect pipes, etc to make a cold air extension, but each time i started my car it would die when i gave it gas, i kept checking the pipes and after tightening down the rubber hoses, etc 5-6times the car ran normal, except that the eninge light came on and today after a 24 hour period it doesnt go away any mnore, and ideas?
NISTECH
check all your connections for intake temp sensor and your airflow meter you still have something disconnected.
book-ends
Car: ???? Nissan 240SX coupe S13
Isn't the minimum time to reset the ECU something on the order of minutes? 24 hours seems like a long time. I really don't know, but it doesn't hurt to ask.
NISTECH
yea easiest way is to disconnect both battery cables and hold them together for 30 secs. that will pretty much discharge everything.
ESPER
r u sure hold both battery cables together??!!? hmmm i will try it after i see a couple of repliesu mean both ends after taking htem off?
NISTECH
yea once the cables are off you use a tie wrap to hold them together and just leave it,come back to it when your ready to go somewhere or what ever. in your case though if you left it for 24 hrs if you didnt still have a failure the light should of went out. that pocess wont work on 96 and up cars though cause the code is burned into a chip in the ecm. unless you have a scaner you cant erase codes from these cars unless you fixed the failure and the car tested it self as good.
NISTECH
you are going to have to find your failure. pull your codes. the code you have is a hard failure if it is coming on right away. most likley a electical connection problem.
4felix20
Car: Emerald Blue S14
maybe that maf is backwards or you're missing a hose...?
NISTECH
4felix20 wrote:maybe that maf is backwards
good point
ESPER
okay i will check today, but how do i pull codes please? thanks!
NISTECH
http://240sx.org/faq/index.html then click on this link on the leftECM, reading trouble codes SOHC it has a really good write up on pulling codes
ESPER
hmm i double checked all sensors and hoses, and put tothether the two cables for 20 minutes and still its on!! could something have gotten in and ruined my engine? or maybe there is more air getting in and its not used to it? it seems to difficult to mess with my KA24DE and i dont want to screw anything up anymore.. *sigh* thanks anyway for all the help!!
NISTECH
pull the codes and see what is causing the light to come on. it will send you in the right direction.
