Starting a few days ago I noticed a small puddle of fluid on the ground under the passenger-side front suspension. I crawled under the car with a mirror and light and couldn't see a source and it really looked as if I'd hit something -- just saw a "splashed" area just on a lower suspension part (control arm?) of the same fluid, but only on the front side (not top) of this member. When the small puddles happened everywhere I parked the car over the next days, I knew it's from the car.
It is a very viscous sticky but mostly clear fluid -- tough to wash off even with hand cleaner. Has a very slight sweet smell to almost no smell at all. I see it coming from a suspension mount (A-Arm?) Not a suspension guy, so I have to look up what it is.
So my questions:
Are there fluid filled suspension bushings on the J? any other ideas?
I'll post more when I look up the part...
Other info:
Car has 93K miles on it; I don't have access to a car lift or engine hoist and only have a couple of floor jacks... (but I do have a flat place to work
