The springs are located on the front of the intake cam gears. You have to pull the top two timing belt covers, then there are three bolts that hold a small cover over the springs. Luckily, you don't have to pull the plenum. Here is what they look like
http://www.czp.us/Cart/descrip...7.177
Here's a DIY for it
http://www.aus300zx.com/forum/...37243
If the noise is coming from the front of the engine, this could help it.
Modified by colincliff2 at 11:20 AM 4/14/2009
Modified by colincliff2 at 11:23 AM 4/14/2009
