migurus »
https://forums.nicoclub.com/migurus-u60763.html
Fri Nov 18, 2011 7:40 pm
2005 G35 coup with 140K miles, all of the sudden started to idle very rough, as if I lost a cylinder. As soon I start driving and rpm goes above 1000 I no longer feel vibration. Took to dealer, they checked coil, spark, cylinder pressure, could not see any problems. Continued to check on exaust, said there is quite a bit of stuff (from cat. converter) in it, will be checking the converter cores tomorrow. I was told there is a high probability of cat. converter being a culprit. Do you think the tech is on the right path? Does it look like a probable cause?
Thanks.
