ericb382 »
https://forums.nicoclub.com/ericb382-u32066.html
Sun Sep 09, 2007 11:29 pm
both times now I have put (on the sr) one around the front 2 intake runners and the other I bolted to the hole on the ex side that is just below the T in the valve cover that the catch can vac hose goes to... it has worked perfectly. this time I dropped it in in ablout 20 min with no help.
Just make sure to have (within reason) as little slack in the chains as possible, meaning mount the leveler close to the valve cover. Also, don't forget the floor jack to help guide the transmission into place. I don't know if this is your first time dropping in a motor, but if so, my single biggest tip, losen the motor mounts before dropping in the new motor, you will have play in the setup and can get everything to line up. This cost me hours, literally, my firs time.
