Engine Help?
5amsC1ub36
So one day i was driving down the road at about 60 miles an hour. And then i heard a knocking sound. So we stopped and then i stalled out. Later on, we had a buddy stop by, and he said it was the rod bearing. And so i busted a rod bearing in 1991 240SX.Yall think it would be better to rebuild the engine or replace the engine or junk the car?Also, how hard would it be to do an engine swap, if i had the proper tools?
x240xdrifter
Car: 1991 Nissan 240sx
cheapest thing to do if find a junk donor car and transplant the same engine in, if not you could do a engine swap if you want, it just takes time and money.
5amsC1ub36
okay i found a '96 240SX with another KA24de, would that work to put into my 1991?
GCIA4LIFE
Car: '93 240SX
Yeai put a 97 engine, in my 93 hatchwhen i did it, i swapped everything off my old block and and put it on my new motoronly thing that will give you trouble is the distrubutor; which is hard 2 time, if you don't know much about cars.
Axel Grungy
Car: 2001 G20 5spd
x240xdrifter
your sig pic is a little big, i can chop it down for ya if you want. LMK
BlackHat
Car: 1989 Nissan 240sx Hatchback
GCIA4LIFE wrote:Yeai put a 97 engine, in my 93 hatchwhen i did it, i swapped everything off my old block and and put it on my new motoronly thing that will give you trouble is the distrubutor; which is hard 2 time, if you don't know much about cars.
Eeeek! I hope you pulled the 93 cams out before you tossed it! =) They're better than the 97's.
GCIA4LIFE
Car: '93 240SX
are they? could you explain why?im pretty sure my new block is a 97 but it might be a 96arent' all the s14 block the same for 95-98?but yea my old block is just sittin in my garage waiting for me to disect
Modified by GCIA4LIFE at 7:18 PM 7/27/2006
BlackHat
I can't remember the specifics (I drive a SOHC =), but the older de cams had a more aggressive setup.
I've seen it mentioned before, might try a search. My roommate has a de and knows about it, but he's not available to ask right now =/
GCIA4LIFE
Car: '93 240SX
alright i searched n from what i understand, theres more low end torque with the newer cams but more hp. with the old school cams
BlackHat
Sounds right, the duration is higher on the s13 cams. Especially the exhaust if memory serves. Again, I don't have a de, but I believe you can swap the cams if you want the extra hp.
GCIA4LIFE
Car: '93 240SX
well i think i would rather have more low end torque than high end hp
