Okay, this is going to sound a little stupid, but I really don't know. My engine consistently runs 220 degrees. I understand that this isn't bad for the engine, but it's roasting me when I drive. Anyways, today I went for a slow drive and it was 65 degrees outside and I wasn't boosting at all - the engine was almost always under 3,000 RPM. Anyway, the engine ran consistently between 170-190.
Before I got home, I decided to test this and revved the engine to 7,000 a few times. Sure enough, the temperature went up to 220 and stayed there.
I know that turbos produce a lot of heat, and I'm running 10 lbs. of boost, but is there anyway that I can get this heat to go out the exhaust and not stay in my engine? Would a turbo blanket help, or does this just reduce the temperature in the engine bay itself?
I should probably say that the car this is in is almost 50 years old and there's very little airflow inside the engine bay. Anyone who's curious can read about it here:
http://www.britishv8.org/MG/DarianHenderson.htm
Thanks,
Darian
