mattd1979 »
https://forums.nicoclub.com/mattd1979-u21551.html
Mon Feb 20, 2006 7:20 pm
I have a problem with cylinder #5 that surfaced shortly after replacing knock sensors and putting the top back on. The cylinder seems to run good when you first start the car but once your on the highway #5 cuts out and the car runs on 7 cylinders. When you come to a stop the car is loping. I'm not for sure if it is the injector or maybe the coil but the problem will come and go while on the highway. The car will be driving rough and then smooth out and gain power and then #5 will drop out again. My Mom is driving my car right now until I can get the fuel line replaced on her 1991 Q which will involve pulling her upper intake off also. What I need to know is weather or not this will damage the cylinder and piston due to not getting any fuel from the injector at times. I have been thinking that this lean condition may burn a hole in the piston. Please let me know if it is safe for her to drive my car like this until I can diagnose further as other then my car, she has no transportation until I get her fuel line replaced.ThanksMatt,Jacksonville, FL
P.S. does anybody know how I can check the coil to see if it is firing as the car is running and also check the injector the same way? Thanks again.
