50Mustang wrote:Got a 1993 maxima with 50,000 from a old guy. Its primo except for 2 things.
1. No power at take off! Engine bogs and runs ruff at idle. However, on the freeway it runs great!!
2. When I put the car in drive the transmission dosent engage right away. When it does however it shifts just fine..
I agree give her some TLC!!! haha replace everything, plugs, wires, air filter, fuel filter, maybe a oil change/oil filter if not done recently, you know just general maintence. as for the transmission not enganing all the way, check your clutch pedal free play (i. e. measure the distant from normal position till you feel resistants, a good rule of thumb is 1-3 inches) if its off adjust your pedal linkage, or bleed your clutch
OH AND WELCOME TO NICO!!!
