i have a 96 240 with a 95 auto trans ecu to eliminate the top speed limiter. my question is if i put a 95 motor with the original sensors on it, and still ran the 95 ecu. will the 96 engine harness still work with the 95 motor. in theory it should you would just have extra plugs on the harness.
will a 96 harness work on a factory 95 motor?
i need to knowthanks, zach.
