Engine harness conector and Ground location questions
RCG_Savage
Car: '92 240sx fastback
1992 240sx, ka24de.
Alright I was hooking the KA's engine harness and I can't seem to find where to hook up this guy: http://img.photobucket.com/alb...8.jpg
Also where is the stock location for the battery ground, There is no evidence of where it would be connected at all, or does it not matter as long as it has a metal connection to the chassis?
Hijacker
Car: '92 240sx Convertible
'94 F-150
I'm not sure about that connection, but a trip to a service manual will help you out.
As far as the battery ground. It grounds on the intake manifold and the chassis near the fuse box.
boosted2forty
Car: 89 sr'd hatch
if you are using the factory ground wire there is a tab in the middle of the wire that connects to the side of the battery tray with a 10mm bolt.
vancouverbc
Car: 1991 240sx
Detonation sensor. Look up code 34 in tutorial link in my signature.If i recall, there is a wire coming from middle of engine from detonation sensor.
