Engine Harness and ABS Harness integrated?
240sxinlv
I have a 97 240sx KA.
The main engine harness was destroyed beyond repair. I could not find the exact harness I needed.
Harness I had - 1997 OBD2 with ABSHarness I have - 1997 OBD2 no ABS
I have not been able to locate a harness with ABS for a year.
Can I buy any 95-96 harnesses. They are a LOT more common. Can I just buy a 95-96 harness and use the couple ABS plugs I need?
Even though the harness is all wrapped together does the ABS go through the ECU at all? I think I could just unwrapped the harness and plug in the couple connectors on the ABS pump and the one down by the ECU?
Anybody?
I want my ABS back.
I kinda like not having it for track days but I would rather unhook it by pulling a fuse instead of it never being there.
THANKS!!!
