Engine goign back in next weekend need to....
Florida240sx
I think I'm going to have my GF's dad make me an intake mani. I just need to block off all the vaccum right?Is there any vaccum line that will be needed? What would I do about the fpr either have a tap on mani or tap from brake booster? 2nd question Heater lines.You got the 2 heater core lines that go into your firewall.Do I need to have them? Would like to not have to worry about How would I go about blocking it off? Or just have a pipe that connects the inlet/outlet? Don't know how it works..... Please enlighten me.
Craving4Boost
Car: 91 240sx fastback
only things that need vacuum is Brake booster and FPR. however, to cut back on vaccuum caps...i suggest you use a hose and plug 2 at a time. you'll plug emissions and other useless stuff twice as fast. just as long as you keep the vaccuum inside
Florida240sx
So how do I go about blocking off my 2 heater hoses?
Joeygsxr
Car: 93 hatchback KA-T
i belive u need them to reatain heat in the car, just run some new lines from the fire wal to the front of the mani...what r u going to do with the "tree" of lil tubes that comes of the back of your head?, thats got me stumped as all hell, dam vacume lines....
Florida240sx
Remove all vaccum...Only vaccum I have as of now. Is off valve cover, the fp,r brake booster line.and the 4 right uner throttle body. All the stuff behind has been removed along with emissions.
emperor_lunchbox
Car: 91 240sx, 96 eclipse spyder, and 96 camaro z28 (For Sale)
Joey, when you are removing your lines you should do a write up. I am interested in removing my emissions and vacuum lines on my spare motor, but I don't know where to begin.
Florida240sx
Only thing you need back there is brake booster and fpr. Then the ones that come off your throttle body to radiator.
