no lie just this week
Matucks wrote:I have a 95 240sx stock engine KA. I decided to buy a walboro fuel pump and installed it the car ran great for about 10 min and then it started throwing alot of blue smoke out the exhaust. I went ahead and replaced all the fuel injectors fuel filter put back the old stock pump because it was giving too much gas to the engine and i changed all the spark plugs because the were flooded with gas. when i start the engine the car shakes alot the first spark plug is getting way to much gas and is isnt burning the spark plug is just wet. it only happens to the first one the rest burn fine. I tried fuel cleaner injector cleaner everything.. nothing works. i unplugged the first injector and the shaking went down alittle but the car began to idle low and cut off.. i replaced the first injector again and same problem it idles then drops and cuts off and the smoke is just flying out the exhaust what can the problem be please help
end i had the same prob after installing new injectors this past weekend it was my second cylinder and my smoke was white but there was gas coming out of tail pipe your injector is not sealing right. did you replace the bushings under the fuel rail? if not do those. fuel pressure reg is attached to the back of your fuel rail fuel lined is hooked to it. its small about the size of an injector. also make sure you use Vaseline to better your seal. make sure both o-rings are replaced plus the bottom bushing and that should help. lemme know how it works out for you.
