Engine Gasket Help??????????
jesse_tijero7
Car: 1991 Nissan 240sx HB with 95 KA swap
Ok so I am currently swapping a s14 ka into my 91 s13 body. So im wondering since im going to replace all the gaskets and seals, Do I need to get the s13 manifold gaskets since im using those and not the s14 ones? Or are they the same? please help...
Modified by jesse_tijero7 at 10:34 PM 6/3/2009
24j0hn
Car: 91' 240sx with some babying to be given
save yourself the trouble and get a gasket set from frsport... it has all the gaskets you need .
http://www.frsport.com/Stone-C....html
jesse_tijero7
yea I was a lil to weary about that ebay set. the way i see it. if parts are cheap they are made cheap! Thanks bro.
24j0hn
no problem, it where i got mine and i can vouch for it
jesse_tijero7
as for the other question. do I need the s13 gaskets for the intake/exhaust manifolds, since im using those on the engine?? or can I just use the same ones from the 95' s14 set
24j0hn
IMO a KA is a KA it should fit... i suggest you ask someone else i havent lined both up and compared...
there is also this one from frsporthttp://www.frsport.com/Gasket-Sets_c_187.html
jesse_tijero7
yea those are the ones im lookin at right now. cuz i have a 95 KA.
24j0hn
but it a little more than wat you were looking at first but itll get the job done
jesse_tijero7
yea its a lil more, but id rather go with the gaskets for the 95'...better safe than sry
