Engine final assembly and fit!
Discuss topics related to the VH41DE, VH45DE, VK45DE, and VK56DE engines.
John Dixon
Car: 300ZX-TT Z32
Actually got the engine in my car this week. Gearbox, starter, clutch and prop all done and starting to work on dry sump plumbing now.Hopefully Wes will put the pics up when he sees this.And yes, red was the only paint I had handy!!
hannibal
Car: Red Line to Glenmont
Wes, are you sleeping on the job?!?
Cant wait to see 5.2L of goodness
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Sorry boys... Decided studying all yesterday afternoon for a test was a better idea than NICO..
CLICK TO ENLARGE
John Dixon
Car: 300ZX-TT Z32
Cheers Wes!Afraid it's not a 5.2, just 5.0l
gs14racer
WoW looking real nice and clean.
I got an off topic question. Why do some valve covers have the window in the side and some dont.
I have like 6 90-93 motors and some have the windows on the valve cover and some dont regardless of the year.
SSDwellah
Car: '90 Z32 Coupe w/ VH45DE + 5-speed (FOR SALE)
'06 Infiniti G35 Coupe 6MT
'08 Frontier 4x4 SE KC
Wow looks nice. I hope my Z32 will look half as good. I don't think I am gonna spring for the dry sump though so I'll have to work out a factory-like rear sump/pickup. I apologize if you get this question a lot and have already covered it but... Is your car right-hand-drive or was the photo mirrored to mess with people?
If it is RHD, what are the laws like in IN that let you do that? (maybe the dry sump should hint to me that its a track car)
gs14racer
He lives in the UK (united kingdom)
SSDwellah
Oh never mind I overlooked the part that the pics were from John Dixon and not Wes
I thought the car was in Indiana, USA. Great job Dixon
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
That is so sweet. I will have to pay you royalties so I can build a sister engine for my Q if I ever modify from stock.
John Dixon
Car: 300ZX-TT Z32
I'll have the full spec sheet on the engine soon so will post that up.If anyone does want any of the parts I can put them in touch with the people that make them (royalty free!!).
David Steele
Car: S13 FastBacK
How did you get 5 liters?
Did you just bore it out?
John Dixon
Car: 300ZX-TT Z32
Yes, its bored to 98mm with new liners fitted.
David Steele
Car: S13 FastBacK
You had the factory sleeves cutout huh.
Do you have a picture of what you replaced them with I'm interested John.
mtcookson
Car: 1991 Nissan 300ZX
1992 Iinfiniti Q45
and much much more
Here's a thread of his with some engine shots:zerothread?id=210654
David Steele
Car: S13 FastBacK
Are they sleeves for a Chevy engine?
John Dixon
Car: 300ZX-TT Z32
David Steele wrote:Are they sleeves for a Chevy engine?
Not sure, the engine builder sourced them from a supplier he uses. Being UK sourced I would doubt they're chevy though. And yes, the old ones were bored out as part of the process of enlarging the bores.If you want I can get some details but I can guarantee that the $:£ rate is going to make buying anything from over here a no go at the minute!
David Steele
Car: S13 FastBacK
That isnt my intention. I'm just trying to find out if the sleeves as we call them in the USA, you were using were a product for another car.
Stinky
John, I'm curious about the fitting for the oil pressure line that goes into the block. Isnt there a threaded port there normally? Why did you weld the fitting on?
John Dixon
Car: 300ZX-TT Z32
Was just easier than using a converter to -10 JIC, its an unusual thread for a hydraulic fitting. Can't remember what now but think its a 1.75 pitch and most hydraulic ones are 1.5.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
I thought the oil pressure tap was a British plumbing fine thread standard?
Godspeed, Master Dixon!
John Dixon
Car: 300ZX-TT Z32
The one for the pressure sender is (I think 1/8BSP) but that would be too small to use as a feed line and by the time there is a converter and fitting on there it would be right in the way of the manifolds.Think the ones stinky means are like the one you can see on the second picture next to where the original oil pressure filter housing was (allen head).
SSDwellah
I would have thought the same thing. I know that the KA24DE's fittings used a BSPT which I think is British standard pipe thread. I heard it dates back to prince motors and some british racing influence.
Return to “VH45DE / VK45DE / VK56DE Forum”
