s14 2510's »
https://forums.nicoclub.com/s14-2510-s-u26808.html
Tue Oct 25, 2005 2:19 pm
He means seafoam through your gas I think. To gut your cat take it off the car and poke away till all the platnum comes out of your cat or till you can see throught it. you should be good to go. You can just buy a cheap de cat of ebay to see if this was your problem or not. also when was the last time u put a new fuel filter on. If you know a mechanic have him hook up a fuel pressure tester so you can make shure you are getting the correct fuel pressure at turn of key, start up, and with a load.
