schanne »
https://forums.nicoclub.com/schanne-u47706.html
Wed Jul 16, 2008 2:39 pm
Took the valve cover off to do this again. I also now have another CAS that I'll swap out to see what happens. Before I bolt everything back up can you guys check the line up of the dots. On frsports write up it says:
"If this procedure is done correctly, the second notch on the shaft should now line up with the notch on the housing, and the CAS position (can rotate it +-30 or so degrees...) should be centered"
Mine isn't exactly centered but the dots line up. Here's some pics, is this right?
