engine diesels???????????????????HELP ?????????
iloveboost
i have a 90 240 with a sr20det when i turn the key off it diesels ...it takes a few seconds to turn off after i turn the key ? anyone know whats wrong?????? thx for all your help
180fan
Car: 89 fastback
what does "diesels" mean? Read the top sticky about how to make a meaningful post. I will edit your thread title when you explain your situation.
UK-SRi
Car: Nissan Cima 2007/2008
If the car carries on running you have a hot-spot that is causing ingition. Start with a good tuneup, then see what happens after that.
Mike
node
How long does it continue to run? Does it run rough, ping, make lots of noise? It is possible that if your injectors are wired in the wrong order.
If that is the case that would cause a lean condition that would overheat the cylendars and could cause pinging and possibly a condition that could lead to dieseling BUT the car would run like complete *** when on.
iloveboost
when i turn the key off it rumbles then shuts off ... its hard to explain with out being abl to make the noise ...
Red coupe
Car: 92 Nissan 240sx Coupe
180fan wrote:what does "diesels" mean? Read the top sticky about how to make a meaningful post. I will edit your thread title when you explain your situation.
Diesel is a meaningful word, its the term for when a hot spot in the combustion chamber causes the cylinder to continue firing after the ignition has been shut off.Could be build up of carbon some where in the cylinder. Thats kinda just a generic answer though...
iloveboost wrote:when i turn the key off it rumbles then shuts off ... its hard to explain with out being abl to make the noise ...
If you could record yourself making the noise and post it im sure we could figure it out
rsmithdrift
Car: 1993 240sx fastback se.
Oddly enough, my car never used to do this untill I installed my electric fans. Now it always does it. I disconnected the fan and turned on/then off and it shut straight off, wired em back in and diesels agains. It's very odd.
I know it has to do with the fuel pump too becease that's what the fan is wired too.
one85_db
Car: 1992 240SX SE S13 KA24DE
rsmithdrift wrote:Oddly enough, my car never used to do this untill I installed my electric fans. Now it always does it. I disconnected the fan and turned on/then off and it shut straight off, wired em back in and diesels agains. It's very odd.
Ah ha!!! when you turn off the ignition the electric fans still rotate, because of this and the fact that it is connected to the positive of the pump and still grounded; what happens is it turns itself into a genarator. As the fan continues to rotate after being shut off it generates power which continues to run your pump after being cut off.
Solution: Use a relay http://www.partsexpress.com/pe...0-070
Pin 86: Positive from pumpPin 85: GroundPin 30: Positive from batteryPin 87: To positive on fan.Pin 87a: Unused
iloveboost
my fans arent the problem here ... so is their any other explanation for this ????
one85_db
hmmm i have to edit this now because i just realised i was talking to the wrong person. I was replying to rsmithdrift not iloveboost. I need more details here to help you. Sorry for the confusion...
If your fans are the problem here it's not because your fans are broke it's just the nature of DC permanant magnat motors to act as generators.
Have you tried the relay; if so what happened? If not then you should not be so quick to jump to conclusions, because i too have had this same problem with my s13; however my approch was different than the solution i gave previously...
I simpley wired mine to the output of the accessory relay found under the stock air intake box, now the fans are always on when the key in in the "acc" or the "on" position.
When the fan continues to rotate it generates voltage the opposite direction of its rotation, so in effect the positive input of the fan becomes the positive output of the "generator" feeding enoph voltage back to the positive input of the fuel pump to cause it to stay on after the key has been turned off. while this is happening the fan is spinning down and generating less and less voltage, which also caues the fuel pump to pump slower and slower untill it stops pumping enoph to cause it to fire. Also depending on how the electrical system is setup in the nissans (i dont know for sure) it is also possible that the voltage could also be feeding back into the igniton system causing an irratic spark, and fireing the fuel without a "hot spot".
A relay would solve both of these problems.
Modified by one85_db at 5:23 AM 5/30/2006
Modified by one85_db at 10:50 PM 5/30/2006
