dattodude »
https://forums.nicoclub.com/dattodude-u30125.html
Sun Jun 14, 2009 1:57 am
Kemp, this requires an ASCII wiring diagram:
This is using a normally OPEN relay.The trick is to 'switch the earth on', and use the best connections you can to reduce the load on IGN.
A lot of people make the mistake of looping 12V from pin 1 to 3, and connecting 2 to earth, and connecting 4 to the FANs (and earthing the fans independently.
Alternatively, you can add an additional relay to control a FRESH high current wire from the battery. This gives a clean 12V feed for things like FANs and Intercooler spray systems.
Caveat: I'm not an auto-electrician, but I did wire up my whole car and CA18 from scratch, including aftermarket ECU and CDI.
