01Blackerado »
https://forums.nicoclub.com/01blackerado-u84167.html
Sat Jan 05, 2008 11:37 am
Honetly...in my findings, Im not sure if this has changed since I looked last but...Nology wires are most likely the problem...try puting the stock ones back on and see if it works again!!? If that doesnt work then the rest sounds like a tuning issue.
I dont kow a whole lot about these cars in particular, im kinda new to 240 modding, but I do know cars!!!
Is the motor swap that you did a bigger motor?? If so then the other problems may be mechanical.....like the throttle body might not have a big enough idle hole to keep the car idling if the motor happens to be bigger or the cam more agressive.
