thekawaii »
https://forums.nicoclub.com/thekawaii-u23206.html
Tue Nov 22, 2005 8:08 am
Here's my setup
bone stock SOHC.T3 from (1986~1987) 300zxS13 side mount intercoolersome fuel upgradesStock MAFcurrently under 7 psiNo BOVhalf inch pipe? right next to O2 censor from original exhause isn't pluged in.alternator is little old
This was happening since i got my turbo installed.
When car is running cold, let say i just started my car, my car runs fine.When i push clutch from high rpm, engine won't let rpm drop less than 800rpm. All cars are like that. Engine should not turn off itself.
But after my car gets warmed up. When i stop my car at red light, engine dies. So to keep it running, i have to do 'heel and toe'. keep opening the throttle little bit while i'm pushing brake.Rpm niddle supposed to stop at 800 rpm, but keep drop like dead, finally engine stops.It seems like car need more air at idle. And idle is not stable when car warms up.
What could be a problem?
