ViolatoR »
https://forums.nicoclub.com/violator-u11572.html
Sat Feb 07, 2009 8:42 pm
Thanks for the suggestions. Ok, put in new TPS and the engine is running again! I think all the cleaning I did helped a bit, but I'm still having problems with the RPM's dropping to around 500 when in Reverse, Drive, 2nd and 1st. The idle is fine (in Park & Neutral), I adjusted it with the TPS and idle adjust screw; engine sounds normal, no odd smells, sounds or smoke, though the engine is still bouncy when at idle. The engine sounds normal when revving up and the RPM's looked normal up and down, except they always went back down to 500 when in Drive.
What happens in the engine when going from Park/Neutral to Drive? What becomes engaged or turned on? Because if this part is messed up, like something with a belt or vacuume hose which is not on or needed when in Neutral, then it would explain why when putting it into gear the RPM's drop out.
Also my spark plug #2 looks brand new. All the plugs are new actually, but the others are blackened already while #2 is still clean. I swapped plug wires to see if the wire was bad, but after running it with a different wire it was still clean, so maybe the injector isn't squirting.(?) I've seen many threads with people complaining about #2, might there be something with the computer in these cars..?
My coolant levels look fine, there may have been a bit of light white smoke in the exhaust when first starting it, and when I turned to AC on, but it's raining here so it's hard to tell if the temperature is making it look more visible than normal. (I added seafoam to gas & oil by the way, incase this explains the whiteness). The AC made the RPMs go up, and when I turned it off they dropped down and stayed at 500 until I turned the car off and on again. The second time I turned to AC on the RPMs didn't seem to go up. The engine temp gauge needle didn't go past the center mark when fully warmed up. Oh yeah, when letting it run in Park with the AC on, the RPM's would drop to 500 every 2 minutes and stay there for about 10 seconds, and then go back up to normal. If the AC unit is crapped out, would it explain why (when the AC is off) my idle RPM's are normal in Park/Neutral and not in Drive? How can I test this, can I just unplug it or take the belt off and and run the engine?
Things I've fixed or checked since the start of this thread:I cleaned out the MAF, IACV and replaced the BPT and its torn hose, and cleaned the EGR as best as I could without taking it all the way off. New plugs, new fuel filter, fresh oil. Checked the timing and everything was TDC at compression and the distributor was lined up to plug #1. Cleaned distributor contact. Replaced TPS. Cleaned some engine grounds which were dirty and checked most of the hoses and grounds, but I'm gonna lift the car up tomarrow so I can get a better view of whats going on at the bottom. I don't have access to spare 240 parts to swap and check, and I can't afford a mechanic, but I do have an autozone gift card. So, I have to do the work myself, but I just need to know what to do!
