Engine died, then weird stuff with idling
hai1206vn
Car: 95 s14 se
Ok, so I was pushing the car for a while and suddenly the engine died at about 6000rpm. Of course braking and steering got heavier. I restarted the engine while the car was still rolling, and it turned back on but the rev fluctuates rapidly between 300-700rpm, then died again.
I brought the car to a complete stop and tried to restart. Same idling problem happened again, and it died. Coolant temperature was still in normal range, and I couldn't find anything that burned in the engine bay. 3 minutes later I retried and things were back to normal
Did anyone experience this? I can only think of 2 possible reasons: (1) either there's some kind of thermostat that regulates the temperature, or (2) the throttle cable was stretched for a long time and got some slack, so couldn't hold the idle rev constant.
Thanks in advance for your input, guys.
jaytv1019
Car: 1995 240sx w/redtop swap
What motor?
hai1206vn
Car: 95 s14 se
ka24de, bone stock
ugadawg
Car: 1997 Nissan 240SX SE/LE
The same thing happened in my Dad's 79 Trans Am. Only everything started working normal after sitting dead for 2 weeks. It could be that your computer was getting some bad readings and shut things down. I really dunno what the cause could be....Let us know if it happens again and more about the circumstances.
hai1206vn
Car: 95 s14 se
I think I've found a similar case, which says that the reason is the speed or rev limiterhttp://www.240sx.org/faq/articles/spdgov.htm(look at the "Rev Limiter" section by Chano, 2nd from bottom)
jaytv1019
Did you test the MAF or fuel system?
Autoshopwing
Car: 240SX SE
Check your ECU for codes.
