Engine died at tip-in
elpiar
Car: 1992 KA-T
Need help. (setup is in my signature)My engine died everytime I blip the throttle from idle (warmed up)
I recently change the injector latency to be 0.5ms. Anyone knows what it should be for deatschwerks 555cc?
Any other suggestions? I got new distributor cap, rotor, sparkplugs
WDRacing
If it worked before you changed the latency, then change it back. If it has never worked, then we need more details. Never heard of a Calum ECU...
WD
elpiar
Car: 1992 KA-T
The thing is, at the same time there were some problems with the ignition system, that's why i changed the dist. cap and rotor and sparkplug. but now the problem is still there after I change the latency back.
Calum realtime ECU rocks! I can testify as a satisfied customer!
http://www.sr20forum.com/calumsult/
