engine datsun 620
1972-1979 Datsun 620 forums. All 620-specific topics and discussion can be found here.
77datsun620
Car: 77 datsun 620
I went to check a datsun 620 pick up out and the motor started up as soon as you turn the ignition but it has like a high idle or something .i was wondering if the motor is messed up or is it still alright. i dont know what a regular datsun sounds like so i dont know if it is weird or not. any help?
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
lol, some more info might help, how high was it idling? should be 750
77datsun620
Car: 77 datsun 620
it wasnt redlining .i don't remember what the rpms were but it sounded as if you were giving a little gas. this is the truck might be buying this week i might just end up doing swap lol
http://fresno.craigslist.org/car/248192206.html
evildky
06 Nissan 350Z GT
wo, looks pretty good, high idel could be a vacume leak or simply idle screw on the carb turned to far, if it's running smoothly I'd think it's an easy fix
77datsun620
Car: 77 datsun 620
alright thanks.
mipo510
Car: 1970 datsun 510
yea dude..should b the carb.....play with the adjusting screws....and c if the throttle cable is a bit tight...
madizmo
Car: 89 nissan 240sx
It's just the carb, ive owned 5 620's and have had a few of them idle very high even with the idle screw adjusted all the way in. either rebuild the carb or just get a wber 32/36 downdraft carb. I have rebuilt a few of these carbs and only one or two of them have worked better then they did, i would suggest to just try and find a weber cause they are easy to find and rebuild and pretty cheap, also give way more pep than the stock hitachi carbs.
Return to “Datsun 620”
