engine damper
zeedakay
Car: s13
does anyone know for sure if the s13 sr and s14 sr use the same brace? thinkin about gettin one for xmas and the prices on the auctions vary alot
mrgreeneyes
Car: ///M5
Parted Out Built S13 Coupe
put ENGINE MOUNTS on your list.
"dampers" are a joke.
TOTAL waste of money lol
S13k
Car: Mazda miata 99 NB
Nissan 240sx 91 s13
mrgreeneyes wrote:put ENGINE MOUNTS on your list.
true that, i think the only time those dampers would be working is when you turn on the engine, after that your mounts will do the rest, even better solid motor mounts
zenki-S13
Car: 1990 Nissan 240sx S13
from what others have told me a while back, they are more less for the "drift car" look
you can only rock an engine damper if your MAD JDM TYTE YO!!!
HoosierSX
Car: 1992 Nissan 240sx, 1971 Chevrolet Camaro
broke 2 stock engine mounts. then installed an engine damper and no problems since. doesnt work? BS....
blacksrjdm
Car: 89 240sx, 99 CBR900RR.
HoosierSX wrote:broke 2 stock engine mounts. then installed an engine damper and no problems since. doesnt work? BS....
Correct, as they said. With stock mounts will make a difference. With aftermarket mounts (harder compound or solid) it is a little bit overkill.
