slakker wrote:Oh it is defin itely worth a try and to tell you the truth there were longer struts available. 24" I am not sure, but it doesnt sound too unreasonable. I the event that the bolt isnt tough enough, It wont cause any damage. Anyway now that ive seen you have a turbo installed, how is it. How much do you think you are putting out, curiouslyI think these struts are awesome and am going to try to mount them to the hood I am making. Why put thousands of dollars into our cars and still have to use that stupid rod. It would be cool if you popped it and it raised itself up...as long as you made it safe.
STB = Strut Tower BRace...
I'd rather use a shorter strut than a longer one, for aesthetic and weight purposes--the other point I showed in the picture is only about 13.5" from a STB bolt--will that compress the strut too much?
And again--will attaching the strut to the back side of the engine compromise the dampening performance? I think I may try it this afternoon...
I love my turbo KA--I haven't taken it out in a while (crappy CT Roads), but I Just installed 370 cc injectors, JWT ecu, walbro 255 lph fuel pump, etc...I'm eager to see how it performs now. It'll be intercooled in about a month (alcohol injection currently).
I hope at 10 psi I'm puting out at LEAST 240 rwhp--I've seen people make 255 rwhp at 8 psi; granted, their kits were better designed, but mine is very similar to other kits out there--my draw back may be the semi-small turbo (T3 super 60 b)--but 2.5" downpipe/exhaust all the way back, no cat, will be intercooled, etc--i think I'm doing a dyno day toward the end of march, I'll know for sure then...
