McGyverBob »
https://forums.nicoclub.com/mcgyverbob-u9959.html
Sat Sep 13, 2003 9:31 am
'92 maxima. having a wierd problem. it cuts-out while driving, sometimes at idle, pretty much whenever it wants. it doesn't bog-down or sputter, or miss...it is like the engine cuts out, then comes back on completely, then cuts out, then full on. as if you had a light switch rigged to the fuel delivery system and ignition. in fact thats what I think it is but the cause is unknown. thought that maybe the alarm system is malfunctioning and is causing this. I thought this because while at a light, several times now, it just dies the same way it dies while driving and the security light begins to flash. any ideas? I also have a post in the stereo and alarm section asking about disarming the OEM security system. maybe thats it. but if not, any ideas?
