PEZi »
https://forums.nicoclub.com/pezi-u122065.html
Tue Jan 24, 2012 1:18 am
Well this could get complicated not knowing the exact condition of the hoses and whatnot. But, it sounds like one of two things. The first one being that there is a hose unplugged somewhere that needs to be plugged... also known as a leak. It's not that the weber needs many hoses to run, but if there is one left open allowing for vacuum to leak, there is a problem. The other thing it could be is something with the timing. If the dizzy has to be turned all the way just to make it run, there is a chance either that the dizzy did not get put back on right (if it has ever been off) or that the timing chain skipped a tooth or was put on one tooth off (assuming it has ever been worked on).
Last, but not least, it could simply be a fuel related issue. If it's running a weber, it needs a pump that is in healthy condition and should most definitely have a fuel pressure regulator on it set to 3.5psi. Hope that gives you something to work with!
