centralcoaster33 »
https://forums.nicoclub.com/centralcoaster33-u27573.html
Wed May 27, 2009 10:16 am
I'm not certain, because you have an s13, but... Has your transmission been out lately? Mine (s14) has a speed limiter of 120mph. Approximately equal to 4200 in 5th gear. I had my transmission out, yes I know it has different position sensors than yours, but when I put it back, the speed-o sensor wasn't plugged in all the way and I'd inadvertantly switched the neutral and 5th gear sensors! I got a couple hundred miles on it before realizing all I had to do for the speed-o was plug it in all the way. A few months after that I got into tracing my transmission position wires and discovered my mistake. Swapped plugs and all was fine. Basically, when I was in 5th, it thought I was in neutral and when it was in any other gear it thought I was in 5th... Be sure to reply with your solution and what the problem really was!
