SVTCOBRA wrote:
Yes, this happened to me years ago with my 84 Dodge Daytona Turbo Z POS.For me, it was using cheap gas. It was clogging my injectors. I dumped some injector cleaner in the tank, started buying better gas, and the problem went away. Perhaps you could try this. And, maybe a new fuel filter??
Regardless, check back in and let us know what the problem was!
And, Welcome to Nico!!
Hey Rich
I can understand bad or water in the gas causing rough engine performance but the op was having an issue with flickering lights leading me to believe the problem was electrical related.
You can correct me if I'm wrong but I believe federal EPA regulations passed years ago required the removal of single bottom metal storage tanks and required the installation of double bottom plastic storage gasoline tanks. Not only did this prevent leakage but also condensation from forming in the storage tanks.
Here in NJ I occasionally I see the state inspectors taking lab samples from gasoline stations gasoline storage tanks.
I personally have never experienced a bad tank of gas. Any large volume gasoline station probably would never experience that problem.
It did happen along the Garden State Parkway a year or two ago from a bad delivery but its still a very rare occurrance.
Of course I can't speak for other area's
