Let me start off by saying I have checked the archives and current postings and have not found any postings on my current problem.
I have been working on my friend’s car occasionally for about two months now doing minor maintenance. I changed her oil and oil filter. All went well. About 1 week after, I decided to check into electrical issues that she had way before I touched the car.
List of electrical issues: Drivers seat does not move automatically when the car is turned on or work intermittently. Also there is a parasitic battery drain.
Car Information: 1991 Q45.
Initial Approach: I decided to check into the parasitic battery drain after the oil change. The battery was being drained in under 10 hours of the car being off. I followed the suggestions in the posting
zerothread/202345. I pulled fuses and found that with the car off, two fuses caused a significant battery drain.
Diagnosis: The Dome lamp circuit and Radio Power Antenna circuit when the fuses are in and the car off caused a high current drain. As much as 1.3 Amps current drain combined with the car off, doors closed, and keys out of the ignition.
Temporary Rectification: I removed both fuses from those circuits. My friend does not need either, as her antenna is broken and the interior light is not crucial to operation of the vehicle. Current draw was brought close to the level found on the form posting I mentioned above and the car battery holds the charge. Woohoo!
The New Problem: We figured we would leave the car that way until I can trace the current drain problem. After I did that however, the car cuts off in cases when she is decelerating or not pressing the accelerator. Don’t make sense to me. As stated, the antenna is broken and the dome light works perfectly fine. It seems ridiculous to believe that critical circuitry was placed on the circuit with the dome lamp and/or power antenna. However, this is all I can come up with unless this is coincidental and something else went wrong at the same time.
New Rectification: Before she starts her car now she replace the fuses and when she parks for a long duration of time meaning more than 6 hours she pulls the fuses out. So far this has worked but clearly this is a pain.
My Questions: 1) Does anyone know what can be causing the current drain on these circuits? 2) Are there any critical components connected on the dome lamp and/or antenna circuitry? 3) If so which one contains this critical component and what is it? 3) Is there a quick fix or any suggestions to fix both issues?
Thanks.
