uneasy »
https://forums.nicoclub.com/uneasy-u143476.html
Fri Sep 18, 2009 10:35 am
I own a 2007 Murano SL with 14k miles. I have been an avid reader of this forum for a very long time and have a tale to tell.
I was driving home from work this past Monday on a 6-lane road (3 in each direction) and going around the speed limit of 40mph. I was about 1 mile into my drive when I went to hit the gas in mid-drive and there was nothing there...no response whatsoever. Luckily I was in the middle lane so getting over to the right was not much of a problem but there was no shoulder. I immediately put on my flashers. I kept trying to restart the car. It would start but the tach would steadily go down, the car would shake and shut off. Finally, once I started it again I revved it really high and then put it into drive and was able to lurch and get off onto a side road. I should add here that in the time I was disabled 4 different "strangers" offered to help which restored my faith in mankind.
Back to my story. I looked under the hood to see if the air intake duct was secured and it was. Oil was fine and I had plenty of gas. I tried to start the car every few minutes and it would just sputter, shake and stall out. I then let it sit for 10 minutes and started it. Everything was fine...a perfect little angel. I made it home, made it to and from work the next day and then brought it into Nissan for a checkup the following day.
They could find no codes and, of course, the car would not fail for them. I told them to hold the car as long as they needed because I considered this a "major" issue. Had I been on the interstate and this happened I could have been killed.
On day two of their having my car, they called to say they checked with tech support and they advised them to check the battery voltage. They found a dead cell. They said the battery powers all the computer systems in the vehicle even if the alternator is operating properly and this caused the problem. Sounds like they were desperate for some kind of resolution to the problem. They put in a new battery and now time will tell.
I have read all the horror stories about the transmissions on this car with early failures. It's human nature to say "this won't happen to me" but as it was happening I was thinking "this can't be true".
No warning lights came on. I have never read of this happening. I usually see where people have been in stop and go driving and go to hit the gas and there is no power.
I now do not trust this car even though I love it. I feel it's flawed and wonder when it will happen again.
Sorry for the length of this but any feedback would be appreciated.
