Magnes »
https://forums.nicoclub.com/magnes-u4718.html
Mon Jun 14, 2004 10:03 am
From the FSM:
"When the MAF output voltage is outside spec, the TPS sensor is substituted to give the ECU an approximation of air flow volume.
It is possible to drive vehicle but engine speed will not rise above 2400 RPM in order to inform the driver of fail-safe operation while driving."
Make sure the MAF is getting clean airflow, and that the connector is solid. There are 3 pins in the MAF connector you can test.
The pin on the driver's side (pin A) should read between 1.0-3.0 V, engine running, depending on throttle opening.
The pin on the passenger side (pin C) should read battery voltage at the harness connector (disconnected, key ON).
The middle pin (pin B) should read 0 resistance between the MAF side connector and ground.
EDIT: If you get code 12 from your ECU that's the MAF error code
