kamuroz »
https://forums.nicoclub.com/kamuroz-u213476.html
Mon Aug 05, 2013 10:13 am
To start from the start, it sounded like a lifter tick... Would only tick when approaching 3000 rpm though. Didn't think much of it, my car is particularly finnicky and does that every time I need an oil change. Which I was going to do today before work. Well, start up the car Saturday, and it sounds like gravel in the engine. So I didn't drive it all weekend. Decided to limp it home last night and klunk, engine jolts and shuts down. Now normally I'd assume I seriously messed up a push rod or a rocker arm or something, but the oil is fine. As in, it's all there, not leaking, and no coolant mixed with it. When it crapped out though it blew all the coolant out, can't quite tell from where though. Can someone explain what happened? Can a stuck lifter/bent push rod blow a head gasket on the waterjacket side only? Or did I do something even worse..?
