unfrgivn »
https://forums.nicoclub.com/unfrgivn-u8387.html
Wed Dec 28, 2005 10:43 am
No longer getting that sputter, it just cranks like normal.
I just set the timing one more time...
Valve cover off, spark plugs out, 1st piston at TDC (double checked with a stick), Timing chain had shiny link down at the crank and two shiny links up on the cam gears so it should be on the compression stroke (correct?). Placed the CAS in as shown in the FSM, put everything back together. Changed the plugs, gapped them to .028, tried to start the car again and it just cranks.
I did the fuel pressure thing and I filled 700mL in 8 seconds. The gas looked normal, yellowish-clear. Not dirty or anything.
I checked compression and I got 158 across the board.
