danger69 »
https://forums.nicoclub.com/danger69-u20467.html
Sun Nov 12, 2006 5:12 pm
Okay now that I eliminated a few things wrong. So here is the breakdown.
Problem:After the engine warms up some where there is a coolant leak. And the temp needle didn't move.
Things Done:I recently replaced the thermostat, drained radiator coolant, drained/cleaned radiator resivoir. Today I refilled the radiator with water. Turned on the engine with heater on high. In a few minutes my temp needle moved for the first time and sits in the middle which is great. Then I noticed dripping from somewhere on the passenger side. I checked around under the car and on top and could not find anything. I turned off the engine and let it cool down. I squeezed the upper radiator hose and I hear a weezing sound like air is escaping from somewhere. I have traced it to a hose that is behind the thermostat housing. What hose is that? I know my thermost housing isn't leaking because I checked that also. Please help.
