Engine Conversion Wiring Issues - Starting
REAPAH
Car: C33 Laurel RB25DE+T
It's not exactly a skyline but close enough, a lot of you guys are pretty clued up on Nissans and may be able to help me out.
I have a C33 Laurel with an RB25DE+t (out of an R32) in it. I have done the wiring myself and everything is ok except for the starting. On crank I don't have any fuel or spark.
I suspect because this is due to the 'KEY SW Start signal' is not wired.
I have located this wire on the ECU side however I am unsure of where to wire this on the body harness. I thought giving this wire 12v would act the same however no luck. Even if I just remove the steering shroud and wire it to the ignition but I am unsure of where this goes. I'm running a Link ECU and am even suspecting tuning issues?
Any experts have an idea? Sick of having to push start the vehicle.
Any help appreciated
