Engine Control Short
NaStY240
Car: 90 Sr240~91 MR2~91 SE-R~91 Civic SI Hatch
I have a problem with my engine control fuse... It keeps popping the fuse, there is a brown wire leading to it. Also there is only fire in the 2nd and 3rd cylinder. 1st and 4th aren't firing. Could this be a dead ECU? There is some corrosion in the ecu when I popped it open but I don't know when or how moisture got in. Where do I start and what would you guys recommend?
Modified by NaStY240 at 6:59 AM 4/21/2009
