I found it. thanks, its under the EC section. egr valve and knock sensor. youve been a huge help and a great welcome thanks!!!allensteiner wrote:hi, you might have a bad connection on the ks harness or a bad sensor - that's easy to check or replace - but i couldn't find anything on the p1400 code in the fsm...
http://www.nicoclub.com/FSM/maxima/1997
maybe the fsm can be more helpful?
