240femme »
https://forums.nicoclub.com/240femme-u10804.html
Sun Jul 25, 2004 3:35 pm
I pulled codes from my ecu today and got a code 32 and a code 34. I read these were for the knock sensor and EGR system. I failed emissions the other day for high HC and CO. I guess the EGR problem would explain my results? Anyway, I would like to know what I need to do to fix these two problems that the codes correspond to. How do I replace a knock sensor? Also, I realize there are a few different components to the EGR system. Should I replace everything, or is there a particular component that would most likely be the problem? Before my check engine light came on, I was also wondering if I had a leaky injector. Should I still worry about that, or would that have had a code along with it?
