Engine code po011/po300 03 Altima
Xaixiss
Car: 03 Nissan Altima 3.5 Stock
Recently my SES light came on, when I hooked up my scan tool I saw the codes po011 (intake (a) camshaft position timing over advanced (bank 1)), po300( multiple cylinder misfire).
Now both bank 1 and bank 2 camshaft sensors were replaced about 1 year ago. Oh and I just check them both again just to see if any sludge or debris built up on them. The spark plugs were changed and correctly gapped 10 months ago and cylinder 3 ignition coil was also replaced. Does anyone have any ideas on what this could be. I haven't been able to find any answers. :frown:
sx moneypit
Car: 2010 Nissan 370Z
1986 Toyota MR2
You could possibly have a sticking or nonfunctional vvt solenoid.
Buckshot
Check your oil po011 code is usually caused by no oil our low oil pressure and have seen it cause po300 multi cylinder misfire.also I am guessing since you did not state engine is that you have a v6 since you have b1 @b2 codes
Xaixiss
Yea it is the 3.5, I have recently changed my oil, but its was doing it shortly before I changed it.
Xaixiss
Does anyone know where the VVT Solenoid is located on the 3.5? Also I cant seem to find the part and any local part stores. Help!!!!!
sx moneypit
1986 Toyota MR2
They are located on the top front of the engine just ahead of the valve covers.
You are most likely going to have to get the part from Nissan.
http://www.courtesyparts.com/altima-par ... _4043.html
-Ben
